ethollis85
- May 10, 2013
- 10
I have recently purchased a 4winds boat with a chrysler 75hp outboard. I asked the guy I work with for his boat guys number becase i knew that he was happy with the work he had done on his boat in the past, but to my surprise the boat guy said not to even bother with it. So i said well i am kinda handy i will go it on my own. The motor is spotless there was a small mouse nest in it and a few wires were damaged I am an electrictian so no biggy there- problem fixed. Now the problems begin new battery checked spark plugs I plan to change to new but different problem. the starter does not seem to have the power to crank the engine. So i found this site with the general theme to get a new starter. so I set out to find a new one but got to the next problem what year is your outboard? So i started to search for the and I came up with these two numbers k986459 which was located on the block and 449544-2 which was located on the motor mounting bracket on the transmission on the boat. the numbers on the starter are 616955 1 28 83.
