I have a 1976 55hp Chrysler that I want to start off the boat and with no ignition switch or controls hooked up. The starter cables are attached and it turns over. I need to hook up the battery to the terminal block and probably jump a couple terminals to start it. Any idea on how to do this. The wires are all color coded as follows: Yellow, Purple, White, Green, Orange, Red, Blue, Black
I can't quite make out the labeling of the terminal block wiring on the engine so I need some assistance. Thanks in advance.
