The above engine leaks fuel from a little hole in the carb. When I pump the priming bulb up tight. The hole is located right above the fuel bowl on the starboard side of the motor. Anyone have any ideas why or how to fix. I don't notice it leaking while the motor is running. Maybe I am pumping fuel up to much, but I've never had an outboard do this before. I just bought this boat and motor. Thanks for your help in advance.
