Hi, I have been given an old outboard that obviously needs wiring up to my boat. There is a connector block on the side of the engine with only 4 wires attached to it.
yellow/black which seems to run through a switch ( starter inhibitor ?? ) to the starter solenoid.
2 black wires which I think are for the magneto
And a red wire which I assume to be the feed out of the engine to the ignition switch that I don't have.
The ignition shall be wired up through switches. ie. power on switch and starter button. Could someone give me a step by step idiots guide to wiring this up. Any help would be much appreciated.
