I recently bought an older pontoon with a 70 horse Force on it. The boat had been sitting for awhile and ran a bit rough the first time out, mostly not wanting to idle well. I could also see a bit of oil on the side of the motor under the cowl. I replaced all fuel lines, cleaned the carb, and rebuilt the fuel pump with new gaskets and diaphram and such. Also installed a new power pack as the old one had an intermittent problem. I also cleaned the motor of all oil and dirt. When I redid the fuel pump, I found a loose bolt back behind it, and one missing completely. I thought this might be where the oil was coming from. Motor is running great now once I adjusted the idle on the water. Spent all day Saturday at the lake and it never gave me any problems. When we left the lake at dark, I decided to pop the cowl off and see if any oil was back., and it was. Problem is, I can't tell where the oil is coming from. The fuel pump side of the motor had a thin film all over it, and it was pooling up in the bottom of the cowl. It also seemed worse than the first couple of times we took the boat out, before I worked on it. The motor is a 2 stroke and is not injected. Any ideas where the oil may be coming from? It was too dark to really see much when we were leaving. The oil seemed very black though. I know I have the idle mixture a little on the rich side, but I don't see where that would cause this.
Any help or ideas would be appreciated. I have the boat stored at the lake, so I can't check anything again until I go back to the lake gain. I also ran it on the hose for quite a bit before going to the lake, and never saw any signs of oil returning.....
