Any and all help will be greatly appreciated. I have a 1997 Force 120 that is new to me last year. I replaced all the reeds and stator and got her up and running. End of the season had issues starting. I thought it was due to cold weather and old battery. This year I got a new battery and I am still having issues starting. It turned over ran for a few seconds then died now I cant even get it to turn past the compression stroke. Tried turning by hand/rope and it is very difficult. Took plugs out and it turns over just fine. I noticed that my prop always spun in neutral. I'm thinking that its having issues overcoming both compression and being slightly in gear. When it turns over should the prop be spinning? Can I try and start with the lower unit off for a few seconds?
