IamCanadian
- Oct 22, 2012
- 78
I belive all the parts I need to do this conversion are.
1 drive shaft
2 leg extension
3 shift link
4 water pick up tube
I had a deal with a fellow iboater to swap my short parts for his long shaft parts as he needed a short and I need a long.
But he is now MIA. So if anyone here has the parts I need kicking around that would be fantastic.
However it is not beyond my skill set to make a 5" extension for the leg and shift link and water pick up, but I only have a question about the best way to extend the drive shaft. I am a welder by trade and was thinking to cut the drive shaft and add a 5" piece of shaft and use collars welded over the 2 resulting joints.
Any other ideas? Thanks in advance!
1 drive shaft
2 leg extension
3 shift link
