Evinrude_NooB
- Jul 21, 2011
- 142
With Jerry's help, I finally bolted my new, used, Force 35 on my Bayliner.
One slight problem now and that is the controls.
I am using the Force 50 controls with the Force 35. I thought they were exactly the same but they're not. Go figure.
The Force 50 has the following control wiring on the motor, in order from top to bottom:
* Start - yellow
* Generator - purple
* Tachometer - white
* Choke - green
* Overheat - orange
* Battery (+) - red
* Ignition - blue
* Negative - black
The Force 35 has the following control wiring on the motor, in order from top to bottom:
* Start - yellow
* Tachometer - purple
* Stop - white
* Choke - green
* Overheat - orange
* Positive(+) - red
* Stop 2 - blue
* Ground - black
I am using the wiring for the Force 50 on the Force 35 motor and the one obvious difference is the tachometer, which is white on the Force 50 but purple on the Force 35.
This is my wiring using Force 50 color wires to Force 35 block. The colors are Force 50 colors and the functions are Force 35.
* Start - yellow
* Stop - purple
* Choke - green
* Overheat - orange
* Positive(+) - red
* Stop 2 - blue
* Ground - black
This caused a short somewhere so the breaker goes off. I removed the Ignition (blue) and the Stop (purple), and the short is gone, but the engine won't fire. It will crank, but won't start.
attached is the picture of the Force 35 wiring block and wiring to the block is from the Force 50 controls.
* Start - yellow
* Choke - green
* Overheat - orange
* Battery (+) - red
* Ignition - blue
* Negative - black
* Start - yellow
* Stop - white
* Choke - green
* Overheat - orange
* Positive(+) - red
* Stop 2 - blue
* Ground - black
* Start - yellow
* Stop - purple
* Choke - green
* Overheat - orange
* Positive(+) - red
* Stop 2 - blue
* Ground - black
