Need more advice, my original problem had only idle speed on my 1986 85HP Force, so i changed out ball pump, got new fuel, replaced related fuel hoses, fuel pump diaphram, all three check valves and rebuilt carborators, but am still not getting fuel to exit the pump to enter the carbs, while i had the fuel pump cover off i turned over engine and put my fingers over the tiny in and out holes on the block and did feel some in and out pressure (dont know if that means anything) i also filled up the outlet hose going to the carbs thinking it needed a little priming, well i got exited for about 2 minutes while it ran like charm then conked out, i think it used up all the gas i introduced into the line but as soon as it ran out it stopped due to lack of fuel. anybody know where i go from here?
