Have a question, on a 87 Bayliner Capri. Posted recently about getting this boat in order. rebuilt carb and ran great.
Today however When testing after running for at least 2 hours at all speeds just puttin around, WOT for a half mile at a time, then putting again for about half hour, I then ran the boat about 3/4 mile at WOT and a buzzer under the dashboard went off, (annoying buzzer) so I shut it down. I had been keeping an eyeball on the water flow and it seemed good spittin a good spray anyway.
This thing has no guages except a speedo, But I am thinking this has to be a temp sensor. Anyone with any knowledge on this please respond. As I know motors pretty well and this sure seems to be pumping water.
After pulling the cover and letting it cool down, the alarm finally went off and I started it up, (good water spary) and we went on running for another hour or so without it tripping again, however I was a little cautious and did not run WOT
perhaps half throttle at the most. Got time to go home and trailered up (no issues)
So All I can think of is either bad sensor, or a glitch. or a faulty thermostat? perhaps not allowing the right amount of water through.
My plan of action is impeller, thermostat, and possible even the temp sensor, if thats what went off in the first place.
any help would be great, as I am not positive thats what the alarm was, but what else could it possibly be.
thanks
thanks
