Hey guys,
I have a 90 HP Force on my bass boat that I purchased about a year ago. I probably had it out about a dozen times last season, and I took it out today for the first time this year.
Just a little background: The motor fires up everytime pretty easily (first few cranks), and runs great at/near WOT. I have no idea what kind of RPM's I'm getting at WOT, and I've never had a compression test done. However, it's been a very reliable motor for a first time boat owner on a budget. Has never left me stranded or anything like that.
The only issue I've had (ever since first time I took the boat out) is the motor wanting to cut off at low speeds, specifically causing a problem when loading the boat back on the trailer. When I'm approaching the trailer and easing off of the throttle, the motor will cut off while still barely in gear. It's never caused any major problems, but it puts me in a potentially bad situation if the boat isn't perfectly lined up with the trailer on final approach, as you can imagine. I basically have to assume I will not have control for the last 10-20 feet of my approach. If I keep the throttle at a level that allows the motor to keep running, I risk running the bow through the bed of my truck lol.
I have a Seloc manual for the motor, and I've heard Force motors are fairly easy to work on, so I could probably figure out something basic if I'm pointed in the right direction. Is there anything specific that I should look for? Is this a timing issue?
Sorry in advance for my lack of knowledge/terminology. I'm pretty green when it comes to mechanical issues.
Thanks!
Thanks!
