Re: how check the timing force 125.
You are correct Hundee r1. It is a safety feature to prevent starting the motor in gear. The neutral safety switch will prevent the starter from engaging if the throttle is not in the neutral position. You can by-pass the neutral safety switch by taking a wire with two small alligator clips and connecting to the two yellow wires on the neutral safety switch, or I use a remote starter switch. I connect one lead to the small yellow wire on the starter solenoid, and the other to the battery terminal on the starter solenoid. Press the button and the starter will engage.
NOTE, you need to turn the ignition key to the ON or RUN position so that the engine ignition Kill circuit is disengaged and it generates ignition spark. Also, since the forward gear is engaged when doing this test, the propeller will spin. Be sure to stay clear of it.
