Glastron_V210
- Jan 28, 2009
- 324
Hey guys. I have a 9hp Chr. that I'm trying to revive.
Things I've done:
1) Cleaned and gapped the points (.020 at max open)
2) Tested the coils and point closing with an ohm meter
3) Gapped plugs
I'm having some trouble with spark. When I revolve the engine, I get a nice blue spark with the plug sitting out and grounded. Godd right? I squirt some fuel into the cylinder, insert the plug and expect a kick or two...but nothing. I checked compression; it's about 85psi...pretty good for an old girl, should be enough for a bang or two.
So, I added timing marks to the flywheel, and used a drill to revolve the engine. Both cylinders are hitting at about 6deg btdc at wot. Should be good.
Here's the curious thing...when I run the plug into the cylinder, I get no more triggers on my timing light. I suspect the compression is causing the spark to not bridge the gap (weak spark).
Any idea or advice? Can the magnet in the flywheel weaken and cause low spark energy??
Chay
Things I've done:
3) Gapped plugs
Chay
