I am looking at purchasing a 1990 Bayliner with a 120 hp Force outboard motor. The current owner said the last time he took the boat out it started up and ran for ~10 minutes and died and he couldn't get it started again. He was told it is probably a head gasket. I wanted to get other opinions and answers from people who have knowledge of this issue or have had the same issue. I know all the normal issues (sticky carbs, bad fuel, bad fuel pump, compression test, loss of spark, etc.) Any other ideas? I want to see if this boat is worth buying or if I will need to put a new motor on it. Thanks in advance for your help!
