I have a 1988 H1258L88B Force outboard. I bought this rebuilt motor a year ago from a dealer. The motor itself runs great, but I'm having electrical issues with the tilt/trim.
I would drive it accross the lake, and after about 10 minutes, while trying to trim up the motor, noticed it wouldn't trim up. The first time this happened, I stopped to check things out, and after not finding anything obvious, attempted to start up again...but it wouldn't start. That time, it turned out the breaker tripped, and after that, all was fine.
The second time, the breaker didn't trip, but it still had the trim issue. It could trim down, but wouldn't trim up. I called the dealer, and was told to replace both tilt/trim relays. I did this, and the problem was fixed...for about 10 minutes...after which, the same problem happened again.
I called the dealer again, and was told to get a new pair of relays. The last pair had been aftermarket, but I made sure to get the Quicksilver brand the second time...which made no difference. Things worked for a few minutes again, and then the trim up stopped working again.
Thinking it may be just the tilt/trim switch on the throttle control, I took that apart, and noticed problems...the insulation on the wires were melted, and some of the bare wires were exposed. I think one of the wires running from the tilt/trim switch on the throttle arm got pinched where the throttle arm connects to the control box (the pivot point where the arm moves forard/backwards).
I know electrical problems are almost impossible to diagnose without tearing into it yourself, but based on everything described, would the most likely cause of the problem have come from the pinched wire making contact, shorting out, and melting the wires around it? Or would it be more likely there was something else wrong with the electronics, and some type of surge happened that melted the wires?
I'm debating if I should just get a new control box, or if I need to take it somewhere to have something else checked out...there aren't a lot of places in my area that like working on Force outboards, and since I've already got enough money into it, would rather avoid a hefty bill from someone else doing it...I'm pretty confident I can do the control box myself if that's all it is (I've already taken it apart and put it back together a few times), but if there's a more complex electrical issue, I may have to find somewhere to take it...in which case, it may just be easier to sell it instead...
Thanks for any suggestions.
