Re: 1991 70hp Force or 1975 75hp Chrysler which better
Well, having done modifications to the 75, you are now not making a stock comparison. The 75 is undoubtably producing way more than stock horsepower.
As far as props alone, you simply can not beat the low end acceleration of the 13 inch diameter with a 10 inch diameter, especially since you have changed to a 2 to 1 lower unit. On the other hand, the 70 does have a more efficient lower unit and is slightly lighter than the 75.
Changing the engine is only a couple of hours work (usually) including the control box. At this time, it is really difficult to say whether or not the 70 will perform equally, less well, or outperform the 75. So, you may just want to experiment. After all, if you don't like it it is relatively easy to change back.
Fuel? If you are going to drive the boat at steady speed less than WOT, let's say 30 MPH, you will use approximately the same fuel with either engine. Flat out fuel mileage will depend upon how much horsepower the 75 is delivering at WOT versus how much the 70 is actually delivering. I never measured but I always felt that port work, in addition to increased horsepower at full throttle, gave me slightly better fuel mileage at partial throttle.
The other positive on your 75 that I never did mention is that you can, with a couple of hours work, upgrade the mid leg and lower unti yp a later model with a one piece lower unit and gain another 2-3 MPH. Everything will fit on the midleg from a 1979 up to 1992 Chrysler/Force 85-125
