Re: mercury force L drive
it got water in it the leak was fixed but when you give it throttle it doesnt spin the prop very strongly guy at shop said possibly the dog clutch or gear? ........does this come out without dropping the lower unit?
This makes little sense.
It either works, or it doesn't.
The guys comment about it not spinning the prop very strongly leads me to believe he is not a good mechanic.
The lower unit has to come off to work on it.
They took it off to replace the seals.
They should have checked out the unit while they had it apart.
I suspect they are either bad mechanics, or they are looking to take more money from you.
