Just bought a boat with a 45 hp Chrysler which was not running. I have installed a starter, solenoid, carb kit, fuel pump kit, new gas tank, new fuel line and bulb, new battery, fresh fuel, lower unit lube, impellar, and spark plugs. The motor fires off everytime while being choked, and will run for a second but dies. I can fire it right back up but same thing. It will die soon whether choke is on or off. I can convince it to run for a few seconds with some heavy throttle but it revs up and still dies. I feel like it is a carb issue but this novice is scratching his head. Fuel can be seen dripping from carb out of choke shutter area. I have been reading on here but this is my first post. Thanks in advance for any pointers. By the way compression is 95 and 107.
