Firstly I have to say this forum is awesome, I've been lurking and reading mostly but now I need some help. I have a 1989 Bayliner Capri with a Force 85HP (Model Number: 856X9B). It seems whoever had this boat before broke the Rod end that connects the tower shaft to the trigger, they managed to zip tie the remaining piece to the shaft and it still works to some extent. I've gotten new parts to replace the broken piece but I can't figure out an easy way to remove the screw that holds it on to the trigger with out removing the flywheel, etc. Is there another way? Its part 32 below, I'll try and get a picture over the weekend.
