Re: Chrysler Powerhead Wanted
Well, What year is your Chrysler? If it is a later one with Prestolite ignition, just about everything will swap onto the Force with no modification. If it is a distributor ignition, then yes, you will need to do minor modifications to swap your ignition onto the Force. But you are correct! It is a Chrysler in Force clothes. (Actually, it is a West bend in Force clothes.) Almost no changes other than cosmetic were made up until 1992
BUT--What is wrong with your current engine? remember, a rebuild should only cost around 1000 for all four cylinders if you do the work (except boring) yourself. AND it is not necessary to rebore all four cylinders if they are not bad, saving some money.
