i have the power head off and also the bottom end...figured now is a good time to check the trim unit...
the unit is on a stand and i put power directly to the 2 motor wires to raise the unit.
it made a "strange gurgley noise at first momentarily and then seemed to work fine going all the way up..
my question is i want to add oil to the unit or should i bleed unit alltogether...how should i go about doing that?
also what fluid should i use? hydrolic fluid, power steering? tranny? i dont have my service manual, my friend needed it back and hes out of town....can someone give me a hand?
