redstrat
- Dec 29, 2011
- 202
I posted this question on my 125 rebuild thread with no response so I thought I would try again. I'm trying to remove the seal from the lower crank bearing. I sprayed it with penetrating oil, heated it with a heat gun, bolted it back in the split casing, and tried a pry type seal puller with a wood block to protect the aluminum. I've puckered out the edge of the seal in several places but it still won't budge. Any thoughts on this will be appreciated.
