To add to the list of woes with my 1993 90-hp Force outboard, the steering appears to be frozen after sitting for over a month. I had greased up the steering column earlier in the season and its hadn't been a problem, though I was using the boat several times a week when it was running. I am trying to trouble shoot the steering to figure out where it is frozen. This is what I tried so far:
1) I had my buddy turn the wheel while I gave the outboard some physical encouragement and motor did not budge
2) Hit the steering column with liquid wrench and repeated #1 without anymore luck
3) I tried disconnecting the steering cable from the motor itself, and I still could not turn the motor or the steering wheel; however after unscrewing the cable nut, I could hardly pull it away from the steering column on the motor due to the pressure/angle that the cable meets it.
Not really sure how to proceed next. Though the steering wheel appears to have some play in it now, is there any troubleshooting that I can do on the steering column on the wheel?
Thanks,
Mitch B.
Thanks,
Mitch B.
