Hi guys
I have another thread going about low water pressure but have another question based on the same topic but felt it necessary to just start a new thread.
I installed a new water pump based on my overheat alarm coming on the other day. But before i actually did anything i watched a few you tube videos on doing this repair myself as i am prety handy. In these couple you tube links im including the guys cap the water pump with a part called a "top seal". Well the kit i bought for the repair 46-43024A 7 did not include this part, and there is no sign that the old water pump had one either. is this a necessary part to help with the water pump pressure? is there to much water passing through the shaft? As of now i have reinstalled the lower end with out it.
please let me know if this part is really important or not and i will purchase one and install it, and why would the kit come without it?
thanks Keith
check at 6min 45sec, its not exactly a "Force" but it is a Merc and the exact same pump
http://www.youtube.com/watch?v=BiQNhFYFvdQ
check at 6min 15sec. again same pump
http://www.youtube.com/watch?v=NtJXv2GqhYM&feature=related
thanks Keith
