ok guys...this is my first post so bear with me...1996 75 hp force runs but runs poorly...135# comp.on all 3cyc.,checked fire with sparky tester with all 3 firing with good blue spark,pulled and cleaned carb with berryman chem-dip cleaner,installed new ngk plugs...engine will crank but as i pull each plug wire with engine at an idle on muffs pulling top plug wire engine dies,replace plug wire re-crank engine pull # 2 engine keeps running,pull # 3 and engine keeps running...so it sounds to me engine is only running on # 1...with fire,comp,fuel whats going on here...HELP
