Had my Force 120 about a year and the charging system will not charge batts. I have bought the snowmobile replacement reg/rec recommended from this forum. No help- sent it back. Another replacement reg/rec with exact part #883071A1 recomended by the forum. I bought another stator thinking the stator was not putting out AC voltage. No help. Pulled the flywheel for inspection, broken magnet(got to be the problem, right?). Sent it off for repair and rebuild. Reinstalled flywheel. No help.... I am reading voltage right out of the voltage regulator, so it is not wiring because the stator wiring and the reg/rec wiring is new. I am only reading batt voltage at any rpm.
So, new regulator, stator, and flywheel. Is there anything else in the charging system that I don't know about. Any ideas?
