Re: chrysler 115hp power tilt and trim leaking help needed
if you had corrosion that bad then it's not worth fixing. too many other issues lurking in the shadows.
if you need boat this year then buy chinese as a band-aid. It should go a year, maybe 2, or three? keep watching ebay and craigslist over winter and grab a fresh-water core from great lakes area. You may even get lucky and get one that works. More importantly you'll have a solid oem to rebuild. after you get it back to 100% right then it's good for 20 years.
