Hey guys, after fishing the other day when i was at the dock I wanted to make a carb adjustment. Pulled off cover an I noticed water in the leg. It was very rough and I took a couple of good shots to the stern and I'm wondering if some water may have gotten thru the cover. Once trailered water drained out as when i got home to flush motor it was dry.
Put it on the muffs and I saw a drip or 2 from exhaust boot on motor leg side. feels a little loose when you move that side of the boot. Question, how does it connect on that side to the outlet holes. it's clamped on the other side. Can it be sealed with silicone or something? It does not seem ripped anywhere just some dripping from the end. Also, looks like a pretty easy fix to replace boot just by reaching in there. maybe little tight, but not sure of how it connects on the non-clamped side. Any suggestions from the experts here?
