Hi,
my father in law has a 55hp 1972 chrysler motor that we want to get running. Do I need serial #, model # for these, or is the year and hp sufficient?
he mentioned one of the problems with the motor was that the points on one of the cylinder seemed to stop working farily regularly. What might cause a point to blow out?
Since we are getting it up and running after some years, my thoughts are 1) carb rebuild, 2) figure out the points blowing issue. Is there anything else I'd want to do in the first run at getting it going?
Also, there are three bolt holes on the top- is that for a puller tool? we are able to get the flywheel bolt off easily, but do not have the puller tool, and I am not sure where to get one (in Toronto).
Are there any resources (parts lists, service manuals) that I did not find on iboats?
Thanks,
Ivan
Thanks,
Ivan
