Re: Flywheel Torque Specs 6hp Chrysler 1978
Thanks for the info JJ! Can you or anyone confirm the 17 or 40 ft lbs on the flywheel?s torque (I saw in my Clymer Manuel)? With a straight edge 40 ft lbs looks closer (aligned in the manual) and sounds better.
""Big Jay, I would suggest this is confirmed before testing vs causing another problem.""
As little as 17 could cause a problem or damage if it should be 40.
