MyUsernameisboring
- Sep 3, 2012
- 1
I'm new to the whole boating scene and ive been having this same problem happen to me for the last 3 times ive went out.. So to start.. I think its a 1982 force 85hp bayliner bass pro fishing boat.. Compression in all 3 cylinders is 150.. From what Im gathering from looking at it, is with the motor OFF And i push the throttle down the butterflies in the back of the carbs open to full.. But with the Boat running and you put the throttle down it will die because the carbs are not opening fully.. what could be the cause?? i am thinking its the timing, It idels fine sounds good Picks up speed But wont go full... When i first put it in the water and go out everything works fine... But if you turn it off and let it sit for a bit and then go back out this happens and only way i seem to fix it is by pushing the throttle down very slowly
