"Ignore the warning to provide extra clearance--this is for racing only. I use Wiseco exclusively on my engines. They are forged, which is stronger than stock. They are easier to assemble, and they come complete with wrist pins and rings."
This is comment from Frank A from previous thread. My question is if these pistons with wrist pins (& rings) are pressed type or uses circlips. Also, does that mean the existing rods and caps with bearing can be used with these pistons?
My '89 125HP started misfiring on the way home but made it the docks. Upon flushing it was not idling properly. Did compression test and #3 is reading 60 PSI compare to the 125's on all other cylinders. Took the head off and the cylinder walls are in perfect shape. There is a little ding on #3 piston around 11:00 but it looks like it's been there for awhile. I have yet to remove the carbs and inspect the reeds. But from the look of #3 piston it looks like I might as well replaced it if I already decided to work this far. Can anybody give me an idea what causes such a ding? Here's some pics.
