Evinrude_NooB
- Jul 21, 2011
- 142
I bought a '87 Bayliner with a Force 50 (Model 507X7B). What is the difference between this model and 507X87B? Both are 50 HP.
Not knowing 'anything' about these engines, I did the best I could to check it out. I put the lower unit in the tub of water, started it, and water was coming out of the pee hole. I never put it in gear while on dry land. I took it to a local lake to test drive it and that's when problems started.
After about 5 minutes of running it, smoke was coming out of it and I smelled cooked paint. I shut down the engine and opened the cowl. It was HOT and smokey. I let it cool for an hour and tried starting it, no good.
Finally trolled it back to launch and took it home.
I checked out the engine, and found the head gasket was blown. Also found out that no water was getting to the head to cool the engine. The thermostat was shot, thermo sensor is probably also shot. Spark plug is potentially gapped incorrectly. It was gapped a bit above 0.040 and I found that it should be gapped 0.030.
Engine isn't seized and the piston and cylinder 'seems' ok. Spark plug wire melted on one side.
Could anyone suggest what I need to check and fix to get this engine operational again?
I have taken the head/cover off and removed the following:
* Head gasket
* Thermostat
* Thermo sensor
I will remove the lower unit and check/replace the water pump/impeller as I'm sure that is shot because no water was coming up to the head. I know because I found some kind of insect nest there.
I noticed a large screw on the top of the engine near the thermostat. This suggests that I could install a tube and connect that and run it out so I can check to see if water is circulating up the head. Is that advisable?
What a nightmare.
* Head gasket
* Thermostat
* Thermo sensor
What a nightmare.
