Force 125 hp outboard 1988
We need to get the gear housing cover off, it is stuck on after removing all the bolts.
Any suggestions that won't result in it being broken?
It seems to be still attached in the center around the water pump.
We have removed....the 4 bolts holding in the water pump and the 3 bolts visibly holding down the cover.
Thanks,
Xev
Thanks,
Xev
