Re: Force 125 outboard tune up suggestions help
Most times the timing won't be changed unless someone has messed with it.
So changing/cleaning the plugs is all you need to do for the motor.
You should have perma-gap plugs, just use a wire brush and carb cleaner and they will last for YEARS!!!
Install a filter between the carb and fuel pump.
Change the impeller and gear oil.
Change the gear oil more often if you use the boat a lot.
The impeller changed at least every 2 years.
Upper Marlboro,guess you use it in salt water.
Make sure you flush after every use.
Do a decarb,I like Mercury's Power Tune.
Some use Seafoam.
Since the ethanol is here to stay, use additives.
