puzzlemanbob
- Aug 15, 2012
- 3
My motor has ran smoothly every year until this one.
Starts not problem but runs very rough and dies.
Found if the roller that contacts the cam is slightly pulled on it runs well again. Ended up installing a clear hose over the roller just enough so cam engages and pushes on roller. It runs smooth now.
Problem is I was reading a post somewhere on here and it was mentioned the cam should not touch roller when in neutral position. Now I am concerned I may be doing some kind of damage running like this.
Any help would be appreciated.
thanks Bob
thanks Bob
