OhSnap
- May 4, 2010
- 77
Hi, I have a 1994 Force 40hp outboard, model # 40ELPT
(has a new battery, also used a second battery to be sure it wasn't a battery issue)
Most times you turn the key and it starts but every once in a while you turn the key to start it and you will hear the bendix gear just spin without contact with the flywheel, just the humming noise from it spinning. If you hold the key for a few seconds it will slowly get faster but the starter gear will never contact the flywheel gear. If I pick up on the starter gear and engage it myself with the flywheel and have someone else hold the key it will just barely (if at all) turn the flywheel and the starter solenoid will start clicking. Even if I move the flywheel by hand with someone else turning the key it has a very hard time turning the engine over. So that manual effort turned out to be useless.
If you keep at it using only the key it will eventually start just fine and will be ok for a few days.
