hornetswarm
- Jun 9, 2011
- 33
Hello,
I just replaced the shift cable because when I got above 3k RPM, the outdrive poped out of gear and reved up but prop did not spin (in-water). The shift cable was snapped at the the mounting point and allowed to much slop causing the shifter to pop out of fwd or reverse when reved up. HOwever, now that I have it all changed out, I was wondering if there is step by step procedure on how to adjust the linkage? I started with halfway point on all three adjustment points. 1. The throttle lever, the outdrive linkage and the pin that the cable mounted to. HOwever, after hours of twisting I can get the gear into forward and neutral, or reverse and neutral, but not all three. I know it is becase I am not adjusting it properly...Any help will be appreciated.
