95 force help with gray tach wire at motor
bigl
put a differnt rectafura on motor but dont have place for gray wire is there someplace else i can hook that up on motor like yellow stater wire think i did that on my older bass boat but it s an older mercury an it worked fine tks once again.
Deferred
Re: 95 force help with gray tach wire at motor
one of the yellows should work to feed tach gray wire. experiment first before splice the wires together, sometimes one works fine and the other yellow does not
