Isaacm1986
- May 20, 2009
- 1,086
So I picked up a 1987 Force 85hp for $200. I has 115psi in the top 2 cylinders and 40psi in the bottom one. I put a new head gasket on hoping that was my issue, but still the same readings. I am wondering what the next step is on this motor? The pistons look nice, and the cylinder walls all look clean and smooth, so i am not sure what would cause low compression in one cylinder.
Is the powerhead worth rebuilding? how good are these motors? just trying to figure out the best options here.
thanks.
thanks.
