Recently I had a 140 HP Evinrude on my 91 Bayliner Capri and I've switched it over to a 85 HP Force motor. I know quite a switch, but long story short I brought the Evinrude in for maintenance as it was hard starting. The marina said "it works great now", guess what? Was worse than before. Took it back to them and they couldn't even get it started. The so-called technician went into his shop and brought out a can of starting fluid. I told him that I had heard that starting fluid is really bad on outboards, he said "no problem, the engine is oiled up now so it won't hurt anything" Well the engine is now toast and of course they won't stand behind what their work. Anyways, I bought a 85 HP Force (1985) for a really great price, before I paid the guy he started it right up, we checked compression and every cylinder registered 120 psi or very close. He put it in gear manually as he didn't have the controls connected, put it in reverse and everything worked as it should. Now I've got the motor attached to the boat and I need help with the controls. When I put the muffs to it last night it started right up but died almost immediately. Stupid me, I moved the connectors on the controls instead of hooking them up just as he had them. So now I'm sure that they are way out of adjustment. Here's the deal. When I pull the control lever out for neutral there is limited travel on the control lever. Lets say that neutral is 12:00, I would guess that I'm getting them to move forward to approximately 9:30-10:00. When I have it in gear (not running) I get full motion on the control lever. I know that the bottom cable is the throttle, whereas the top cable is the gears. I'm stumped. I tried looking at the screw for the cable for adjustment but cannot determine the previous position. If I have these backwards please let me know. I am not an expert and definately need some help. Anyone who can offer some insight would be greatly appreciated. Dan
