Re: Welsh plug sealer.
Thanks for the help Jerry.
By shellac I take it you mean the French polishing type. I have plenty of that.
I should be able to get an original plug here in Australia. The only problem I’ve found is that the small nuisance items can be on backorder for a long time. I have had a needle for the float in the carb on order for about 7 weeks. The old one is working OK so it’s no big deal.
Thanks for the offer of sending a plug to me. If I need it badly I’ll just have to fly you out here with the plug to fit it!
I’ll let you know how I go with this home made plug. If it works I could add it to my product list. Engagement rings, wedding rings and silver ,gold or platinum welsh plugs. For the boater who has everything.
