I have a 1988 Force 50hp outboard. I am having issues with the starter not firing regularly when I turn the ignition. To date I have replaced the ignition, the neutral lock and the starter solenoid. I have also verified that the kill switch is good. I also fully charged the battery to make sure that was not the issue. I thought it might be the starter, but when I jump the solenoid it starts right up. Randomly the ignition will work and I think the problem is fixed only to have it not work again. Any suggestions? For what it is worth, the choke on the ignition works all the time.
