Went out on Monday (July 30th) and the boat ran great for a while. I opened it up, etc. I went into the cove where all the sailboats tie up and was running slow. Looked around at the sailboats and then came out of the cove. I never shut down the engine the whole time.
When I got into open water, I hit the throttle to go fast and it planed very slowly. Eventually, it reached about 25 mph. Normally, it goes about 38 mph on my 1984 Bayliner Capri 16 ft.
So I went from everything was fine, to it wasn't. I knew to check the siphon bulb, check the air vent, check the connections throughout the fuel system, etc. I also switched from one fuel tank to another to make sure the fuel wasn't the problem.
The motor is a 85HP Chrysler Force engine. 3 cylinders. I pulled the plugs and made sure they were clean, etc.
Finally, after talking to 3 dealers (no one wants to work on these things anymore, i.e. lack of parts, etc.) I took it to a dealer about 25 miles away.
I live in Central Ohio - near Columbus. Does ANYONE (including a garage mechanic) work on these or are able to in my area?
