I am reboring my 88 50hp after a broken ring scored a cylinder. Do any of you have experience or insight using wiseco pistons? Have you had luck with them? The prices are as good or better than oem cast and appear better made. Is there anything I should tell the machine shop such as leave .002 in the rebore for honing/break in? Any advise and input good or bad with your wiseco rebuilds is appreciated.
