hunter9999
- Jul 27, 2012
- 6
Hi all
Having a little problem with my outboard.
I was out at the lake running along just fine then it started missing really bad then died....So tried to start but it won't, so started my way back to shore with the oars and trolling motor......about half way there I tried again and it fired up still missing really badly but got us back to the dock and up on the trailer.
Sooo opened it up and found there was a very weak spark on number on number 4.. soooo swaped coils and it started working so I said great I'll order a coil..4 days later get a coil in the mail and install it....Well still a very weak spark on 4 and I am beside myself trying to figure it out.
So so far I have
Swaped the new coil up and it fires great when it is in number 3 place...
Checked the compression just for fun it is 155 psi on all...
So here is were it gets weird so I swaped CDI boxes and bamm 4 is a good strong spark and number 2 is weak, but number 4 is still not combusting I can unplug it and no change (while the CDI boxes are swiched and only running on 2 cyl) So to me I seemed the timing was screwed up on 4 cause I have fuel (plug was wet) and good compression.
So I checked the Trigger 56ohms on all and check the Stator ohms are right.
So I am a little bit stumped maybe you guys can shed some light on the subject
Thanks In advance
Hunter
So so far I have
Thanks In advance
Hunter
