Hi to all on this forum, I have a 1968 Chrysler 55hp that recently needed a new shift control cable. The guy who was supposed to install couldn't get to it for another week but already took out the old shift cable w/o remembering how things came apart....My questions to all are below:
1) Should the shift cable connection inside the control box look like how i installed it (connected through left hole closest to the motor) or should the plate the connection runs through be flipped so the connection would be on the right hole farther from the engine???
2) Why is it that my tower arm (specifically the idle adjustment screw) doesn't retract all the way back so the idle screw touches the block (there's constantly a gap between the idle adjustment screw and the block, which I feel isn't right).....it's been like this I believe since I owned it which has contributed to the motor jolting into gear w/ a bit higher rpms than I think it should have while going into gear....If anyone could enlighten me, I would appreciate it..
3) Does the shift control connection at the motor look fine?...The little metal flap that catches the groove in the shift cable could've been w/ the screw on the bottom (flipped upside down)....the way I have it on there right now is w/ the screw on the top of the shift control cable..hopefully someone else w/ an old Chrysler would know what is the correct way up or down ??
4) The shift cable connection at the end, I was just wondering if this looks like about where it should be for how much thread is left on the cable....If anyone has any pictures of there's I would really appreciate it.
Please look at all the photos below and tell me what you think to each question (especially you chrysler owners!)...I've been holding off on doing these small adjustments for a few weeks now and really want to get out on the water, Thanks to any questions answered!
