Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Correct Impeller kit?
  • Correct Impeller kit?
    I ordered an impeller kit for my 1998 Force 90 hp outboard a few weeks ago. I got the Sierra 18-3570 from iboats. Is that the right one? I already put it in, but it is still struggling to get water out the tell tale. Thanks!
    1991 Bayliner Capri - In progress
    Email Me!
    Re: Correct Impeller kit?
    I emailed someone at boats dot net and they said it was part number 43024A7. Similiar to Sierra 18-3570, but looks like a few extra things.
    Email Me!
    • #3
      DId they say the impeller was the same? How are you testing it, in the water or with muffs?
      "If it ain't broke....don't worry, 5 minutes with me and it will be!"
      1996 Trophy 1802 - 120hp Force (by Mercury...snicker)
      8' Hardbottom Dinghy w/Evinrude 6hp OB (oh yeah, this is the 'boat')
      In the market for nice, local area, sailboat, with the operative word being-"cheap"
      • #4
        Iboats said sierra 18-3570 first time i chatted with them the day I bought it. I chatted with them today and now they said they don't carry the kit for my outboard....
        I emailed boats dot net and they said it was part number
        43024A7.
        I don't know if it is the same. I'm testing it with muffs.
        Email Me!
        • #5
          When you put it in, did it have a nice, snug fit on the driveshaft and did you have to twist the tines to fit into the housing? If it was loose anywhere, probably want to do a "do-over" on this one. IF not, do you have access to a very large trash can or 55 gal drum that you could submerge the engine in? I've had 'em struggle to spit water on the muffs but pee like a champ when in water. The best thing, however, is to get a infrared thermometer and check the actual temps on the heads when she gets warm. Lots of people rely solely on the water coming out of the telltale but still end up with an issue.
          • #6
            Yeah and I had to twist the tines as I put it in.
            What I'm worried about is that the
            43024A7 kit has an extra piece (top left in pic) that is pretty big. Also two cylinders extra
            Here is a picture of the Sierra 18-3570:
            Email Me!
            • #7
              They're just two different kits, but probably for the same model. The point is, as long as you didn't pull those "extra parts" out of your boat and discard them, meaning you replaced the parts with new parts that were in your kit, then odds are you have the correct stuff. If you didn't need those "extra parts", doesn't matter that you didn't have them. Have you checked your thermostat for proper operation? What caused you to order this kit and start this project anyway, was it overheating or you didn't like the amount of water flow coming from the Telltale? Just changing the impeller, they probably use the same impeller for several different models.
              • #8
                How do I check the thermostat? I've had the boat for 7 years and only had it replaced the 2nd year. It just didn't seem to be spitting out water like it used to.
                Email Me!
                • #9
                  The '98 Force 90 used a different lower unit.
                  No aftermarket manufacturer lists an impeller or a water pump kit for that motor.
                  Iboats sells aftermarket parts.
                  If you want the correct part, with all the parts, you buy it from a Mercury dealer.
                  Part Numbers : 43024A7, 46-43024A7, 4643024A7 are the Mercury part number.
                  The 18-3570 kit they sold to you is an aftermarket kit made by Sierra, and doesn't have the pump base, the grommets, the drive key, or the bolts..
                  This pump is the equivalent of Mercury part number
                  817275A2
                  And will fit these Mercury motors.
                  40 (4 stroke)(4cyl) Bigfoot, OT228405 & Up
                  50 (4 stroke) 935cc Big Foot, OG231123-OT178499
                  50 (4 stroke) 996cc Big Foot, OT178500 & Up
                  60 (3 Cyl.) Bigfoot, OD000750 & Up
                  60 (4 stroke) Bigfoot, OT178500 & Up
                  65 Jet, OC283222 & Up
                  70 (3 cyl.), OA996142 & Up
                  75 (3 cyl.), OC222000 & Up
                  75 (4 Stroke), OG960500 & Up
                  80 (3 cyl), OA996142 & Up
                  80 Jet, OD283222 & Up
                  90 (3 cyl.), OA996142 & Up
                  90 (4 stroke), OG960500 & Up
                  100 (4 cyl.), OB209468 & Up
                  115 (4 cyl.), OC100000 & Up
                  125 (4 cyl.), OD283222 & Up
                  Mercury calls for part number 43024A7 for your motor, and they sent you a pump
                  that equates to Mercury part number 817275A2.
                  For the thermostat, you take it out, set it in a pan of room temp water and put it on the stove.
                  As it heats, is should open at 130*.
                  A Merc dealer charges $17 for that thermostat. (aftermarket is $32)
                  Medford, WI
                  • #10
                    So you are saying they are the same, but the sierra kit doesn't include all the pieces???
                    From this picture:
                    I don't have the piece labeled 31. Seems like that is why it would work better in a tub or in the lake.
                    Email Me!
                    • #11
                      18-3570 and 817275A2 are the same, except for the missing parts.
                      But your motor calls for part number 43024A7.
                      THe same? no.
                      Close? yes.
                      They used a lot of misc parts from the warehouse in 98 and 99.
                      Things they could use to get by, as the Force line was being discontinued.
                      Medford, WI
                      • #12
                        What would happen if the part labeled 31 wasn't installed?
                        Email Me!
                        • #13
                          I do have part 31. I took the lower unit off to inspect. It was stuck on the top inside.
                          Email Me!
