Re: Force Primer System
Yes, it is fed from the top carb bowl.
The pressure is from the primer bulb in the fuel line that you squeeze before you try to start the engine. This should fill the carb bowls, and supply gas to the enrichment (primer) valve.
Enrichment valve only dumps gas while the key is being held in.
To test, pump up the fuel hose primer, remove the output hose from the valve, turn the key to on, and push the key in.
Gas should flow out the hose.
What is your starting issue?
Is this a new problem?
Did it start easier in the past?
Link to diagram:
http://www.crowleymarine.com/mercury-outboard/parts/1116_90.cfm
