ahickman
- Jul 5, 2012
- 79
After receiving the new water pump kit yesterday, I went to work on pulling down the lower unit. Took over an hour to remove all the bolts. Very intense owing to amount of force needed to remove several bolts. They were heavily corroded and lots of aluminum oxide power flushed out. Once exposed, I could see the shaft was rusted as well. Light sanding and then I unbolted the four water pump bolts. Pulled the housing and impeller out. Pretty bad shape with lots of pitting. No wonder there was no water flow.
I was very suprised at the grooves on the lower shaft. Is this normal?
Got everything cleaned up and ready to reassemble. Chased the bolt holes with a thread to clean them out a bit. Started to tighten the four water pump bolts down to about 15 ft/lbs and the last one cut loose. Threads totally crumbled. Really wasn't a suprise, but surely was a dissapointment. Now I have to tap that hole out and re-thread it. There is not much aluminum to work with around the bolt hole. Anyone have a recommendation on what bolt/thread size I should use?
